[FIRMWARE] I9000XXJVT Android 2.3.5 (29/09)
- Très bonne
153
73%
- Bonne
44
21%
8
4%
- Moyenne, à la limite parfois
1%
- Trop buguée
1%
Nombre total de votes : 210
Messagepar powerda » 05 Oct 2011, 17:34
Salut à tous ;)
Je vous fais une copie de mon post sur XDA, enjoy.
http://forum.xda-developers.com/showthr ... ?t=1289875
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.5
ro.build.date=Thu Sep 29 11:43:43 KST 2011
ro.build.date.utc=1317264223
ro.build.type=user
ro.build.user=se.infra
ro.build.host=SEI-22
ro.build.tags=release-keys
ro.product.model=GT-I9000
ro.product.brand=samsung
ro.product.name=GT-I9000
ro.product.device=GT-I9000
ro.product.board=GT-I9000
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=GB
ro.wifi.channels=
ro.board.platform=s5pc110
# ro.build.product is obsolete; use ro.product.device
ro.build.product=GT-I9000
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=GT-I9000-user 2.3.5 GINGERBREAD XXJVT release-keys
ro.build.fingerprint=samsung/GT-I9000/GT-I9000:2.3.5/GINGERBREAD/XXJVT:user/release-keys
# Samsung Specific Properties
ro.build.PDA=I9000XXJVT
ro.build.hidden_ver=I9000XXJVT
ro.build.changelist=617736
ro.flash.resolution=720
# end build properties
Installation:
Ramad:
"Flash using 3 files: CODE as PDA, MODEM as PHONE and CSC-HOME as CSC, you don't need to flash the big CSC file.
I did not flash the firmware yet, just looking at the files and the firmware looks good so far."
Flashez le firmware avec 3 fichiers dans ODIN car il y en a 4 une fois dézippé: CODE comme PDA, MODEM comme PHONE et pour le CSC choisissez le "HOME".
LINK
http://www.multiupload.com/474JS6Q0IC
FAST MIRROR (Thanks to Grooby)
http://www.samsung-updates.com/upload/SU-i9000XXJVT.zip
TUTO : FLASHER LA JVT (2.3.5) POUR LES NULS Par flo2lacanau
ROM :
Android 2.3.5. - XXJVT
Date de création : 29 sep. 2011
Merci à powerda/powerdams pour le le partage du firmware JVT !! Je ne sais pas où est-ce qu'ils vont chercher tout ça mais ce sont des pro !
AVERTISSEMENTS :
- si vous n'avez pas la combinaison de touches pour passer en mode Download... ne continuez pas !
- un flashage est une opération toujours délicate, soyez attentifs et ne vous précipitez pas
- le flash vous fera perdre vos données et vos applications, pensez donc à faire une sauvegarde par Titanium Backup par exemple
Ce tuto vous permet de mettre en place Gingerbread 2.3.5 officiel sur votre téléphone (version Odex "contructeur").
--> Attention, je ne suis pas un expert ! Je suis juste un utilisateur qui partage une méthode qui a marché ... si votre téléphone se bloque, explose, ou autre, je n'y suis pour rien ... tout ce que je peut vous dire, c'est que chez moi et pour d'autres, ça a marché du 1er coup ...
TELECHARGER LA ROM :
ROM JVT contructeur : i9000XXJVT.zip (256.24 MB) (fichier à décompacter)
Version DEODEXED de Ramad !!
Si vous ne l'avez pas déjà, téléchargez : Odin 1.85
FLASHER LA ROM :
--> N'oubliez pas de sauvegarder vos applications, SMS et vos contacts via Titanium backup (sauvegarde par lot) et CWM.
--> Vous devez pouvoir accéder au mode "Download" (Volume Bas + Home + Power... un menu jaune avec un panneau et le mot "DOWNLOAD" apparaitra), si non, ne continuez pas !...
--> Flasher sur un téléphone avec au moins 50% de batterie pour éviter de tout planter en plein flash ...
ATTENTION : ce sont des versions "wipe" qui effacent toutes les applications et paramètres de votre téléphone lors du flashage (n'oubliez pas de tout sauvegarder avant).
--> Flash avec repartition et PIT 512 :
Cette méthode permet de re-partitionner la mémoire du téléphone. Si vous avez déjà flasher avec répartition et pit512, ce n'est pas forcément la peine de le refaire. Si c'est votre 1er flash, alors continuez avec cette méthode permettant de re-partitioner et optimiser votre téléphone.
- Éteignez votre téléphone et retirez la SIM et la SD externe (ne le branchez pas et ne l'allumez pas avant que ce ne soit marqué)
- Vérifiez que Kies soit bien fermé (le logiciel et le résident aussi, en faisant CTRL+ALT+SUPPR vous pourrez vérifier dans les processus si "Kies" est présent ou non)
- Lancez Odin (si vous rencontrez un message d'erreur, faire "Exécuter en tant qu’administrateur" via le clique-droit de votre souris).
- Cochez "Re-Partition" (auto-reboot et f-restet time coché aussi)
Note : les Bootloaders s'installent automatiquement sans cocher la case "phone bootloader update".Cette case doit rester vide.
- Appuyez sur le bouton "PIT" et sélectionnez le fichier "s1_odin_20100512.pit"
- Appuyez sur le bouton "PDA" et sélectionnez le fichier "CODE_I9000XXJVT_CL617736_REV03_user_low_ship.tar"
- Appuyez sur le bouton "PHONE" et sélectionnez le fichier "MODEM_I9000XXJVT_REV_00_CL1064602.tar"
- Appuyez sur le bouton "CSC" et sélectionnez le fichier "GT-I9000-CSC-HOME-MULTI-OXAJVT.tar" CE FICHIER EST NO-WIPE ... mais j'ai constaté des bug si on ne fait pas le reset factory/wipe data aprés le flash ... donc faut faire un wipe dans tous les cas...
Note : il y a un second fichier "GT-I9000-CSC-MULTI-OXAJVT.tar" (86 Mo) qui est plus gros que l'autre, mais apparemment il n'apporte rien en plus, seulement des fichiers son et vidéo échantillons samsung en plus ... ET IL EST WIPE
Note 2 : pour ceux qui flash la version DEODEXED de ramad, c'est plus simple, il y a 3 fichiers qui commencent par PHONE_..., PDA_... et CSC_... donc on ne peut pas se tromper ... CE FICHIER EST NO-WIPE ... mais j'ai constaté des bug si on ne fait pas le reset factory/wipe data aprés le flash ... donc faut faire un wipe dans tous les cas...
- Démarrez votre téléphone en mode "Download" (Volume Bas + Home + Power... un menu jaune avec un panneau et le mot "DOWNLOAD" apparaitra)
- Branchez le téléphone au PC
- Attendez que en-dessous de "ID:COM" (dans Odin) une case jaune apparaisse (cela confirmera que votre téléphone est reconnu et détecté)
- Dès que cette case jaune apparait vous devez appuyer sur "START" (dans Odin toujours)
- Une jauge de progression apparaitra au dessus de la case jaune, laissez faire et ne touchez à rien (cela dure 1 à 2 minutes)
- Une fois le flashage terminé votre téléphone va redémarrer tout seul, laissez le faire, cela prend un peu de temps (5 minutes max), le 1er reboot est un peu long.
- Passer le tuto smasung du début. Et voilà ! (laissez l'anglais pour l'instant ...)
Ça doit ressembler à l'image ci-dessus
RESET FACTORY
ATTENTION : CECI FAIT UN "WIPE" DE VOTRE TELEPHONE. Si vous avez flashé la version NO-WIPE ceci nettoiera quand même votre téléphone...
--> Si vous venez d'une autre version, un "wipe data/reset factory" permettra de partir sur une base vraiment propre !
--> cela permet de remettre à 0 les paramètres en fonction de la nouvelle ROM installée.
Comment faire :
- Eteindre téléphone, passer en mode "recovery" (vol haut+home+power), descendre sur "wipe data/reset factory" et valider ...
- puis faire reboot système now.
NOTE : vous pouvez faire un "wipe data/reset factory" quand vous voulez, surtout si votre téléphone bug.
FIN du passage en 2.3.5 !
ROOTER LE TELEPHONE
Ceci est une option, le kernel de base marche très bien, mais les kernels custom fonctionnent encore mieux, rootent le téléphone et incluent CWM.
(PS : Titanium backup ne fonctionne qu'avec des téléphones rootés !...)
- Télécharger CF-Root pour JVT
Kernel CF Root pour JVT :
http://forum.xda-developers.com/showthread.php?t=788108
- Vérifiez que la case "Re-Partition" ne soit pas cochée
- Vérifiez que le champ "PIT" soit vide
- Décochez la case "Auto Reboot" !
- Appuyez sur le bouton "PDA" et sélectionnez le fichier "CF-Root-XX_OXA_JVT....tar" (décompacter le .zip)
- Attendez qu'en-dessous de "ID:COM" (dans Odin) une case jaune apparaisse (cela confirmera que votre téléphone est reconnu et détecté)
- Une jauge de progression apparaitra au dessus de la case jaune (avec KERNEL écrit), laissez faire et ne touchez à rien (cela dure 10 secondes)
- Une fois le flashage terminé la case bleu (au dessus de la jauge de progression) passera au vert avec le message "Done" dedans
- Une fois que cette case est passée au vert : débranchez votre téléphone puis retirer la batterie. Vous pouvez fermer ODIN.
- Remettez votre SIM et votre carte SD (si vous en avez une)
- Remettre la batterie et la coque
- Allumer le téléphone ... il doit passer tout seul en français après avoir mis le code pin.
POUR CUSTOMISER VOTRE NOUVEAU FIRMWARE JVT, c'est par ici:
viewtopic.php?f=18&t=19753
powerda
Message(s) : 14
Re: FIRMWARE I9000XXJVT Sep 29 - Android 2.3.5
Messagepar myrmey » 05 Oct 2011, 17:39
Bon il n'y a plus qu'à attendre les kernels, je vais aller voir tiens !
ORANGE OPEN ILLIMITÉ
[N4][Android 4.4]
[KERNEL]STOCK
Image<< lien >>
myrmey
Message(s) : 2128
Messagepar powerda » 05 Oct 2011, 17:40
Le kernel de semaphore 1.7.5 fonctionne avec ; )
powerda
Message(s) : 14
Messagepar myrmey » 05 Oct 2011, 17:47
powerda a écrit:Le kernel de semaphore 1.7.5 fonctionne avec ; )
Le root est ok donc ?
[N4][Android 4.4]
[KERNEL]STOCK
Image<< lien >>
myrmey
Message(s) : 2128
Messagepar Josephou » 05 Oct 2011, 17:49
Un link de téléchargement pour le kernel de semaphore ?
Numéro du Modèle : Galaxy S GT-I9000 + SD 4Go
Version du micrologiciel : 2.3.6
Version de la bande de base : I9000XXJVU ODEX
Version kernel : 2.6.35.7-I9000XXJVT-CL617736 stratosk@semaphore #Semaphore_JVT_1.8.2
Numéro de version : GINGERBREAD.XXJVT
Modifications : Lagfix : OFF MOD : JVT_MOD_SLD_209A_BASE + SWYPE_JVT_SLD + TW3_MAJ_SLD_V2.01_4I.G by stef_ladefense
Forfait : SFR Illimythics 5 Webphone 1h
Outil de travail : Ordi 300 Go disque dur, 1Go RAM, Processor AMD Turion 64X2 sous windows vista + Odin 1.85
Josephou
Message(s) : 98
Messagepar myrmey » 05 Oct 2011, 17:53
Josephou a écrit:Un link de téléchargement pour le kernel de semaphore ?
wouuuu le vilain :o
c'est la dernière fois :lol:
http://galaxys-team.fr/viewtopic.php?f=18&t=15546
[N4][Android 4.4]
[KERNEL]STOCK
Image<< lien >>
myrmey
Message(s) : 2128
Messagepar byakuya » 05 Oct 2011, 17:53
http://www.galaxys-team.fr/viewtopic.php?f=18&t=15546
Htc One (Silver/32 Go)
byakuya
Message(s) : 1277
Messagepar Josephou » 05 Oct 2011, 17:56
Merci beaucoup ^^ désolé de ne pas l'avoir demandé plus gentiment !
Josephou
Message(s) : 98
Messagepar Rutjan » 05 Oct 2011, 18:01
Et on s'abonne au thread!!
Rutjan
Mobile: Samsung Galaxy S GT-I9000
Version micrologiciel: 2.3.6
Bande de base: I9000XXJVU
Mods: CF-Root + JVU_MOD_SLD_220g by Stef_ladefense
Forfait: SFR Webphone 1h
Rutjan
Message(s) : 347
Messagepar Josephou » 05 Oct 2011, 18:02
Le pit 512 est nécessaire ? :-)
Josephou
Message(s) : 98
Utilisateur(s) parcourant ce forum : Google [Bot] et 4 invité(s)
